2003-12-25 03:54 AM - last edited on 2023-05-24 12:51 PM by Rubia Torres
2003-12-27 01:39 AM
2003-12-27 05:14 AM
Ignacio wrote:Ferenc's great contribution deserves to be here too, therefore I am copying his message from GDL Talk:
I posted the same message in GDL-Talk and Ferenc pointed me the way: the script I need to start from for my custom panel surfaces is not the Skylight but one of the standard macro roof surface patches used by 'Roof Surfacer', in Roof Accesories.
Skylight GDL object should be good for an opening (with proper flashing, framing, glazing, etc...)GDL Talk is a place to discuss GDL in more depth, so if you feel like it, go to:
For roofpanels you should take a look into the RoofSurfacer.gsm RoofAccessory object.
What it does is creating the trim polygons for the holes and perimeter of the roof, and calls a rectangular patch of roofsurface.
(rotated according to the reference line position).
By creating additional roofpatches, you can achieve various kinds of treatments. Take a look at the supplied standard roofpatches.
Hope this helps
Ferenc
2003-12-28 08:34 PM
2003-12-29 01:07 PM
Ferenc wrote:
But at any rate, the Accessories are great tools to pass the parameters (including geometry) of a wall/slab/roof to a GDL object, and even updates when the element changes (like moving a door).
2003-12-30 04:41 AM
david wrote:Methinks this is a good item for the wishlist ... both as implementation of the tool AND the GDL command!
Can we expect something like ROOFHOLE in a future edition?
