2008-04-22 09:57 PM
2008-04-23 03:15 AM
2008-04-23 06:13 AM
James wrote:Roofs can't either, can they?
It seems that wall accessories can draw true arcs, while slab accessories cannot...
2008-04-23 10:30 AM
Thomas wrote:No, they can't. Only wall accessory produces true 2D arcs.
2008-04-23 01:58 PM
Olivier wrote:Well, the wall accessories directly ask the walls if they are curved, since there's a subtype parameter for that. On the slab, you would have to analyze a series of points to see if it might represent a curve. It would hurt my head and it wouldn't be very robust IMO.
I am afraid you will have to adapt wall accessory 2D data to slab accessory, to achieve this. Good luck, and a lot of patience.
2008-04-23 03:35 PM
James wrote:Guess we'll need a new 3D engine before we get that. But put it on the wish list!
Why can't that ac_coords data be in x, y, s format, like it would be if you saved the slab as an object? Instead it's this weird hack to say where the polygons end, and no other status codes in sight.
2008-04-23 04:03 PM
James wrote:You are right. We lack a subtype parameter for curved slabs/roofs.
2008-04-23 06:45 PM
Olivier wrote:It's approximation!
@Howard.
May be you already did it? I remember a nice slab accessory you wrote.
