Straight run stair with multiple intermediate landings
Is it possible to make a straight run stair with multiple intermediate landings?I am trying to make a stair which goes to a depth of 12 meters . I could only make stair with one landing in between .Thank you
alemanda
Investigate on "create stairs using selection" of fills and lines ... And also consider to split the stairs into 2 or more simple stairs.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
thank you Alemanda .Will try on that. but still I wonder if option for multiple landings was incorporated while customizing the stair design in a single go. any way thanks for the reply .🙂
https://youtu.be/HbPlFm8gZ3M
