ā2016-02-14 09:06 AM
ā2016-02-14 09:36 AM
ā2016-02-16 07:54 PM
alemanda wrote:thank you Alemanda .Will try on that. but still I wonder if option for multiple landings was incorporated while customizing the stair design in a single go. any way thanks for the reply .
Investigate on "create stairs using selection" of fills and lines ... And also consider to split the stairs into 2 or more simple stairs.
ā2016-02-17 04:17 PM
jje92 wrote:https://youtu.be/HbPlFm8gZ3Malemanda wrote:thank you Alemanda .Will try on that. but still I wonder if option for multiple landings was incorporated while customizing the stair design in a single go. any way thanks for the reply .
Investigate on "create stairs using selection" of fills and lines ... And also consider to split the stairs into 2 or more simple stairs.š
