‎2005-03-14 12:29 AM
‎2005-03-14 03:44 AM
‎2005-03-14 07:21 AM
Peter wrote:It does use COONS. I actually can get 3-sided tents starting from the default parameters, which turn into black dots as soon as I change one or two corner heights. And I just went to a visible 3-sided tent, changed it to 4-sided, and I get the black dot again.
The COONS command needs
four sides. Just a thought
‎2005-03-14 07:46 PM
‎2005-03-15 09:16 PM
Ignacio wrote:Hi Ignacio, try this one, it should work better with 9
I downloaded the free 'Tentmaker_2004-2', which is Frank Chin's Tentmaker updated/upgraded by Georg Weber and Olivier Dentan, .. .and I am having lots of problems which I think may have to do with the 'use of real numbers can lead to precision problems' thing.
Has anybody fixed this, ...
‎2005-03-16 07:47 AM
Olivier wrote:You have just made my life so much less miserable. Thank you so much, Olivier.
Hi Ignacio, try this one, it should work better with 9.
‎2005-03-16 10:30 AM
