The Elevator Object
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-09-14 02:21 PM
I find the elevator object interesting, the option to make the elevator "read" the story height is great BUT...this option causes problem too, if i want to have a different height for a special level (not the same of the story), the object doesn't allow anything other than the story height, the "edit story" button doesn't even seem to work (the story height still greyed)...
am i missing something ?
thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-15 03:12 AM
Gerald
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-15 02:34 PM
This is just one of the problems with Stairmaker stairs which leads to people not bothering with it - they model stair in 3D on hidden layer and then do the 2D symbol manually.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-18 01:39 AM
the only flexible solution as mentioned in an earlier post; is to have the elevator object from the 9th edition of AchiCAD library....the new one is usless in my case (even though it gives more options especially for 2d ) ...
...GS Please fix it .
to be continued
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-04 01:13 AM
In my project I have two separate buildings, with different heights. I need elevators in both buildings and seems it it not possible to use the elevator "outside" the defined stories.
Anybody has managed to solve this?
Thank you!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-05 12:31 AM
The general idea is to make use of hotlinked MOD files
to bring in a "building" with different story heights
than the the building you are working on. Of
course the MOD file can be a partial building or
even just an elevator.
Snap
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-05 03:45 AM
Snap wrote:I suspect that this would not work since the elevator part will adjust to the current project and story height settings.
Search with "multiple building story heights".
Snap
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-05 06:19 AM
For the other building just turn off the walls in the elevator object and build the shaft walls with the wall tool.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-05 11:31 AM
Erika wrote:Which is something you should do anyway if you want to get correct quantities from your model.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-10-08 08:59 AM
Shouldn't be as hard to implement...
