Unwanted element ID when creating new objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-09-27 03:32 PM
2016-09-27
03:32 PM
Whenever I try to create a new object the element ID is always filled when later placing the new objects. Is this connected to the object subtypes??
How can I control what element ID is filled out when placing a new object?
Kind Regards
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-09-27 03:45 PM
2016-09-27
03:45 PM
Element ID is just based off what you last had there.
Let's say I place a sink and name the ID 'sink-01' it will start numbering from there, but if I change the sink object to a car object, the ID won't change.
If I make a new object and place it, it is just using whatever you had there for ID of the previous object you were placing.
If you want to automate the ID field a bit, you can make favourites of objects you use a lot, or a legend of sorts with a lot of objects readily placed with the element ID set up the way you like.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
