Bruce
Unwanted geometry merge
When creating two PRISM elements side by side with no gap between, is there a way to maintain a separating cut line?
The ArchiCAD default is to merge / clean up touching geometry - but I would like to maintain a separating line without having to create a gap between.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
11 Replies 11
Bruce
There is another way to 'force' a separating line between geometry of the same fill type: create a PLANE where you need it. A PLANE will not merge with a PRISM, allowing you to keep geometry separate, without having to create a gap, or use different fill types.
Still a workaround though.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Lingwisyer
Guru
So like;
IF GLOB_VIEW_TYPE = 4 then
PLANE 4,
x1, y1, z1,
x2, y2, z2,
x3, y3, z3,
x4, y4, z4
endIF
Ling.
