I've been updating/changing older object scripts and saving them using AC19. I've noticed that in schedules the changes don't take affect until I open the properties of the object and then close. I don't have to make changes to the object, just open properties then OK out of it. I have to do this for each placed instance of the object or the schedule doesn't change for that instance.
Is there a setting that I'm missing to auto update after a script change?
I will add that when I save the new copies of the objects, so far I've saved them all as embedded objects.
Any thoughts?
Doug
