Using custom image for shrub object
brittsax
I am trying to use a custom image for the built in shrub object and the image I have loaded is not showing up on the object in 3D. The object just appears white. It even appears white if I don't use a custom image.
The goal is to place a logo on the building and I am using the shrub object to place a custom image like Shoegnome Architects tutorial.
AC25 USA • iMac 27" 4.2GHz Intel Core i7 | 16 gb ram • OS Catalina 10.15.7
12 REPLIES 12
Thank you! This worked
Thank you Jared! The picture object worked. Thanks again for your videos they are very helpful!
my pleasure! Hoping to get a bunch more videos recorded later this year.
Jared Banks, AIA
