WALLNICHE with hotspots editing it's section
I have made a window hole with editable section, which can be controlled on a floor plan.
The problem with the wallniche in this case is that I had to use pyramidal cut shape to make it work for every window edge, and with this mode the cut can only be SQUARE (with side length = A).
The goal is not only to make it rectangular, but also with one arched side.
Any ideas which way should I go to achive it?
Maybe some of you have already tried to do an object like this?
4 REPLIES 4
alemanda
I think you can cut and then add other volumes in order to get the rrquested shape.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Yes I know, I forgot to mention that I will do it the way you said if I won't find a better solution here.
And a better solution means using only cuts, because adding extra volume cannot contain wall layers - or am I mistaken?
alemanda
I think that you can add volumes and consider them as wall layers
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Great!
Can you please explain it to me how can I do it? Or show it to me?
edit: I mean the real volume visible in 3d view and in a section, not the floor plan symbol.
