Window and door labels disappear
I use the label function for windows and doors in elevations and sections. When I open the project some of the labels disappear and I need to turn those on again. There are each time different labels missing.
Hi Horwi
It helps to let people know which version AC you're using and some specs of your computer. We usually put these in our signatures - people can't respond unless they know more of what the problem is. With your signature and a little more info, someone may be able to help, hopefully.
I presume your question is "What setting is making these labels disappear, and why always different ones, seemingly randomly? Obviously you want them to remain, every time you open the project.
Someone ... please help Horwi - I introduced him to the Talk, and it would be really good if someone could help.
Erika Epstein
Howri,
There has been a bug in 10 where labels have disappeared, but it seems to have been fixed in 1010. Perhaps not. You might try the file on another computer and see if the problem persists. If so, send it in to your tech support for analysis.
Another possibility is to check the layer(s) that the labels are on and verify that this layer(s) is turned on as part of the layer combination.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Check also the library version that you are using. There has been problems with labelling, and some library parts are more problematic than the others.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
