Polar Bear
Window on curved wall
I placed this window on a curved wall but would need the frame to be perpendicular to the wall surface, like the hole on the same wall.   I wish the same for doors and windows.
Is it possible?
Thanks
Kr
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
5 Replies 5
Surely the frame needs to be perpendicular to the glass/door leaf as you have it now.
Otherwise you will need curved glass/door leafs.
What I think you mean is the side of the frame needs to be built out to allow for the wall hole to be perpendicular to the wall.
I don't think this is something that can be done with the windows though.
You would have to add a curved empty opening and model some packers to the side of the frame.
Polar Bear
Thanks for the reply.
This is for a project in India, everything can be made with carpentry.  The bottom/ top part would be straight and the side jam cut angle to match that site masonry constraint.  It is easier and cleaner to adjust wood than stabilised earth blocks... I have been using empty opening etc. as you suggested, but it is so cumbersome, not easy to adjust, lining up etc...  I ultimately end making quick sketch and discuss with masons and carpenter.  But was wishing to have the model accurate.
Thanks!
Archicad 25 - 5010
David O
Hi Have you tried the curved window in the special windows section of the library, I have attached a screen shot for an example, I hope it helps!
Regards
David
Geof Gainer
Hi David,
How do you get the sides of the curved window to be perpendicular to the walls? When I try it they wind up parallel to each other no matter how I adjust the reveal, see attached.
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
David O
Hi Geof
I am not sure how you did that I can't replicate it my reveals are always like this in the screen grab.
