‎2004-04-23
06:49 PM
‎2023-05-24
12:50 PM
Rubia Torres
‎2004-04-27 05:28 PM
‎2004-04-28 12:11 PM
‎2004-04-29 10:20 AM
Ede wrote:As far as I know you have to script the curve to suit the curve of the wall - not easy. Sorry.
I generated an autoscripted non rectangular window, which works excelent in a straight wall but it dosen't in a curved one![]()
‎2004-04-30 06:26 AM
‎2004-04-30 01:41 PM
HANIEL wrote:You will probably have to use the BPRISM_ command for the Window. Do not use the WALLHOLE command as the cutting polygon of WALLHOLE cannot be bent in space as BPRISM_ can. Instead, use another BPRISM_ for the wall piece between the polygon of the Window and the enclosing rectangle of the Window.Ede wrote:As far as I know you have to script the curve to suit the curve of the wall - not easy. Sorry.
‎2004-05-02 03:58 AM
