Windows in curved walls
I generated an autoscripted non rectangular window, which works excelent in a straight wall but it dosen't in a curved one
Can anyone help me please ?
Thanks a lot !
! 3D Script
! Written by ArchiCAD
MULX A/18.5246010346
MULY B/2.484291118305
MULZ ZZYZX/ 0.15
ADDX -107.9578706926
ADDY 53.7619946784
BODY -1
MODEL SOLID
RESOL 36
GLOB_SCRIPT_TYPE = 3
GLOB_CONTEXT = 3
GLOB_SCALE = 100
GLOB_NORTH_DIR = 90
GLOB_DRAWING_BGD_PEN = 91
GLOB_FRAME_NR = -1
GLOB_EYEPOS_X = 27.98737469476
GLOB_EYEPOS_Y = -84.39104662613
GLOB_EYEPOS_Z = 34.13436039076
GLOB_TARGPOS_X = 67.39849710141
GLOB_TARGPOS_Y = -68.69104927478
GLOB_TARGPOS_Z = 7
GLOB_SUN_AZIMUTH = 133.9949139947
GLOB_SUN_ALTITUDE = 35
BODY -1
BODY -1
BODY -1
BODY -1
BODY -1
BODY -1
GLOB_HSTORY_ELEV = 3.5
GLOB_HSTORY_HEIGHT = 3
!!Slab-050
PEN 2
GLOB_LAYER = "Floors"
GLOB_ID = "Slab-050"
GLOB_INTID = 3437
BODY -1
cPRISM_ "Wood", "Wood", "Wood",
75, 0.15,
117.2201711985, -53.46984858573, 15,
116.9522397687, -53.36681223243, 79,
116.4128620588, -53.17012300814, 79,
115.8701337986, -52.98287717959, 79,
115.3242203081, -52.80513178366, 79,
114.7752878781, -52.63694096333, 79,
114.2235037185, -52.47835595116, 79,
113.6690359083, -52.32942505367, 79,
113.1120533436, -52.19019363666, 79,
112.5527256868, -52.06070411136, 79,
111.9912233145, -51.94099592154, 79,
111.4277172658, -51.83110553148, 79,
110.86237919, -51.73106641485, 79,
110.2953812946, -51.64090904453, 79,
109.7268962926, -51.56066088334, 79,
109.1570973502, -51.49034637564, 79,
108.5861580335, -51.42998693991, 79,
108.0142522562, -51.37960096222, 79,
107.4415542264, -51.33920379063, 79,
106.8682383935, -51.3088077305, 79,
106.2944793949, -51.28842204078, 79,
105.7204520032, -51.27805293113, 79,
105.1463310728, -51.2777035601, 79,
104.5722914864, -51.2873740341, 79,
103.9985081021, -51.30706140741, 79,
103.4251556997, -51.33675968307, 79,
102.8524089282, -51.37645981469, 79,
102.2804422515, -51.42614970924, 79,
101.7094298964, -51.48581423069, 79,
101.1395457987, -51.55543520464, 79,
100.5709635507, -51.63499142387, 79,
100.0038563479, -51.72445865479, 79,
99.43839693683, -51.82380964482, 79,
98.8747575618, -51.93301413068, 79,
98.69557017532, -51.97115523581, 15,
98.69557017532, -53.7619946784, 15,
117.2201712099, -53.7619946784, 15,
117.2201711985, -53.46984858573, -1,
98.84557017532, -52.04228736918, 15,
98.84557017532, -53.6619946784, 15,
117.0701711984, -53.6619946784, 15,
117.0701711735, -53.51954755853, 15,
116.801928303, -53.41753685816, 79,
116.2619541456, -53.22293574945, 79,
115.7186569707, -53.03781454082, 79,
115.172203195, -52.86222993659, 79,
114.6227602024, -52.69623571988, 79,
114.0704962921, -52.53988273622, 79,
113.5155806274, -52.39321887794, 79,
112.9581831842, -52.2562890695, 79,
112.3984746982, -52.12913525372, 79,
111.8366266132, -52.01179637897, 79,
111.2728110283, -51.9043083872, 79,
110.7072006453, -51.80670420295, 79,
110.1399687157, -51.71901372326, 79,
109.5712889878, -51.64126380851, 79,
109.0013356533, -51.57347827419, 79,
108.430283294, -51.51567788364, 79,
107.8583068285, -51.46788034162, 79,
107.2855814582, -51.43010028896, 79,
106.7122826141, -51.40234929802, 79,
106.1385859027, -51.38463586919, 79,
105.5646670527, -51.37696542825, 79,
104.9907018603, -51.37934032471, 79,
104.4168661364, -51.39175983114, 79,
103.843335652, -51.41422014331, 79,
103.2702860846, -51.44671438145, 79,
102.6978929646, -51.48923259226, 79,
102.1263316209, -51.54176175204, 79,
101.5557771281, -51.60428577064, 79,
100.9864042521, -51.67678549638, 79,
100.418387397, -51.75923872195, 79,
99.8519005513, -51.85162019118, 79,
99.28711723517, -51.9539016068, 79,
98.84557017532, -52.04228736918, -1
BODY -1
!!Slab-051
GLOB_ID = "Slab-051"
GLOB_INTID = 3448
BODY -1
ADDZ 0.025
5, 0.1,
102.5004903771, -51.40709976124, 15,
102.3004903771, -51.42549599172, 15,
102.3004903771, -53.7619946784, 15,
102.5004903771, -53.7619946784, 15,
102.5004903771, -51.40709976124, -1
DEL 1
BODY -1
!!Slab-052
GLOB_ID = "Slab-052"
GLOB_INTID = 3449
BODY -1
ADDZ 0.025
5, 0.1,
106.2054105789, -51.28740906684, 15,
106.0054105789, -51.28320042693, 15,
106.0054105789, -53.7619946784, 15,
106.2054105789, -53.7619946784, 15,
106.2054105789, -51.28740906684, -1
DEL 1
BODY -1
!!Slab-053
GLOB_ID = "Slab-053"
GLOB_INTID = 3450
BODY -1
ADDZ 0.025
5, 0.1,
109.9103307807, -51.58671380096, 15,
109.7103307807, -51.55973738792, 15,
109.7103307807, -53.7619946784, 15,
109.9103307807, -53.7619946784, 15,
109.9103307807, -51.58671380096, -1
DEL 1
BODY -1
!!Slab-054
GLOB_ID = "Slab-054"
GLOB_INTID = 3451
BODY -1
ADDZ 0.025
5, 0.1,
113.6152509824, -52.3168222539, 15,
113.4152509824, -52.2659954668, 15,
113.4152509824, -53.7619946784, 15,
113.6152509824, -53.7619946784, 15,
113.6152509824, -52.3168222539, -1
DEL 1
BODY -1
!!Slab-049
GLOB_ID = "Slab-049"
GLOB_INTID = 3428
BODY -1
ADDZ 0.065
cPRISM_ "Glass", "Glass", "Glass",
38, 0.02,
98.69557017532, -53.7619946784, -1
DEL 1
BODY -1
WALLHOLE 38, 0.02,
DEL 1
BODY -1
6 Replies 6
Ede,
I has been four days and and no replies to your post.
Apparently no one can think of a way to
autoscript a curved window into a curved wall.
I know I can't exept to use GDL which isn't autoscripting.
The only thing I can suggest is to keep just the
the hole cut in the wall by deleting everything in the
3D script except the "add" commands and the
"WALLHOLE" command and build your window
in Archicad with walls and roofs.
Peter Devlin
I know, it's not so simple to make a window to fit in a curved wall, I tried to understand the procedure from the examples I find in the GDL reference manual but whiteout any success and I hoped somebody could help me on the forum.
Anyway thank's for your help I will try it as you said.
Best regards,
Ede Abos
As far as I know you have to script the curve to suit the curve of the wall - not easy. Sorry.
in every window setting, model section have straigh line and curve line. Since your wall is curve, you can just click curve line. I hope this help
You will probably have to use the BPRISM_ command for the Window. Do not use the WALLHOLE command as the cutting polygon of WALLHOLE cannot be bent in space as BPRISM_ can. Instead, use another BPRISM_ for the wall piece between the polygon of the Window and the enclosing rectangle of the Window.
That's the closest I can imagine, but it sure is not simple.
Laszlo
Thanks for your advices, it wasn't easy but I did it, it's not perfect yet but it can be improved.
Special thanks for Laszlo's advice which was a good start point.
The hardest was to create the arched top of the window, I didn't used
poly arcs before.
Here is what I realised following the GDL reference manual and
David N-Cole's manual called "GDL for beginners":
!2D script
toler 0.001 !curve resolution
rot2 180
project2 4,90,1
del 1
!3d script
bprism_ frmat, frmat, frmat,
7+7, frdep,r, !r radius of curved wall
-a/2,0,15,
a/2,0,15,
a/2,b-1.5,13,
-2.543,-30.448,900, !set arc centerpoint
0,32.70,4000, !arc using centerpoint and angle
-a/2,b,13,
-a/2,0,-1,
-a/2+fwid,fwid,15,
a/2-fwid,fwid,15,
a/2-fwid,b-1.58,13,
-2.543,-30.448,900,
0,32.40,4000,
-a/2+fwid,b-0.08,13,
-a/2+fwid,fwid,-1
addz 0.04
bprism_ "glass", "glass", "glass",
7,0.02,r,
-a/2+fwid,0,15, !fwid= frame width
a/2-fwid,fwid,15,
a/2-fwid,b-1.58,13,
0,32.40,4000, !arc using centerpoint and angle
-a/2+fwid,0+fwid,-1
wallhole 7, 1,
-a/2,0,15,
a/2,0,15,
a/2,b-1.5,13,
-a/2,b,13,
-a/2,0,-1
Thanks for all.
Best regards,
Ede Abos
