Windows in object library not working
So every time I try to change any of the parameters on the windows in my ArchiCAD 10 object library, I get the message "Group operation error at line 870 in the 3D sript of file wa_trim_us_10.gsm" If I click continue, I can make the change, but this message pops up every time! Then, when I try to view the window in 3D after inputting it into my project, I get the message "Library part was not converted properly (W03)".
Can anyone help me fix this?
David Pacifico
If you wall is 8" or smaller you will need to select the window/s.
Change the "Wall Type" to Stud wall OR change how far the window is set back in the wall.
Always set the wall type and the reveal size before placing a window/door.
The Reveal Size is what sets the window back in the wall.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
