Wrought Iron Scroll Object
I am trying to find or create an ornate "S" wrought Iron scroll for a balcony railing.
Are there any good sites out there that offer those objects or details how to build one?
J
8 Replies 8
Djordje
You can build it - if it is flat - with a slab.
You can also use TrussMaker. Also flat.
Curved? Heh ... start with the flat slab, read up on BWALL.
If it is needed only for rendering (don't think so ...) draw the texture in Photoshop or something else, apply.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Wall tool and save as an object gives you a lot of control over the shape. (Check 'Object Making' in the ArchiCAD Help menu.]
Also check out this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=8924&highlight=railing
vfrontiers
(trying to conserve on Forum Topics)...
I am trying to find a Wrought Iron Basket... Looks like the picture below...
Maybe I can get creative with the RAMP object...
Anyway, if you know of one that exists out there in the ether, let me know....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Erich
Duane,
You could play with the SWEEP command in GDL...as I recall, it has a rotation that you can set for just such a twist.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
I don't have it but I would not be surprised if it turned out that you can do this with Objective.
vfrontiers
2 min. with the Ramp Object got me this...
Could spend some time adjusting parameters... it's a little "loose", but good enough for now..
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
ok.... another dig on the new library schemes for TW2...
The object below; seeming very simplistic, is a 10mb file... no joke!
So the dig is having all these parts EMBEDDED into my file is a killer!
Duane
Visual Frontiers
AC3.14 - AC29
Maybe you could reduce the resolution of the model with the RESOL command in the 3D Script so it will create those twisted surfaces out of less planes. Which will result in smaller file size.
Maybe 16 or 12 will be sufficient instead of the default 36.
