blue and orange dots
how do i turn off these blue and orange dots showing??
4 Replies 4
Hi, those dots are from missing library parts.
You should fix the missing library parts.
ok yeah ive just realised that the cadimage windows and cadimage roof arent showing i have installed the archicad educational version but also have a commercial lisence. how do i get rid of the educational version and just use the other archicad license?? it seems to default to the educational version
If you double-click on a file to open it, it will open with the most recently installed version of Archicad. So you can either open the correct version of Archicad first, then browse the recent file list to select your project (always my preference) OR uninstall and reinstall the commercial version so it becomes the most recent.
stefan
Are they two separate installations? If it is a single folder, you may have to remove the education.lic license document from the ArchiCAD folder (and insert your dongle if you use one).
Archicad-user since 1998
my Archicad Book
