code for text poping up
Does anyone know how to code a roomtag so that when the square foot of the zonetag goes over a certain size a warning text comes up. I can make the text white so it doesn't show up on plans.
Thanks for any help,
Michele
4 Replies 4
Hi Michele,
Use the print command...
PRINT expression [, expression, ...]
Writes all of its arguments in a dialog box. Arguments can be strings or numeric expressions of any number in any sequence, separated by
commas.
Examples:
if dim>x then PRINT "Opssss"
PRINT J, K-3*L
PRINT "Beginning of interpretation"
PRINT a * SIN (alpha) + b * COS (alpha)
PRINT "Parameter values: ", "a = ", a, ", b = ", b
PRINT name + STR ("%m", i) + "." + ext
If you want it to display on the plan you can do something like:
IF room_area > max_area THEN
    TEXT2 x1, y1, "Max area exceeded"
ENDIF
Note that the variable names (lower case) are just examples that I made up. You would need to chose whatever works for you and make sure they have the right values.
Keep in mind that the white text will still obscure whatever lies under it.
Thanks,
I'll have to also make a toggle to turn it off once I've seen the warning text.
Thanks again,
Michele
What I've seen people do is create a scale-sensitive toggle in the script, use some scale that never goes to production drawings for this type of checks with script-generated information, and save that into a view. That way you don't need to mess around with object settings, and your production views and drawings are always clean and final.
