code for text poping up
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-11-08 07:29 PM
2007-11-08
07:29 PM
Thanks for any help,
Michele
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-08 07:55 PM
2007-11-08
07:55 PM
Hi Michele,
Use the print command...
PRINT expression [, expression, ...]
Writes all of its arguments in a dialog box. Arguments can be strings or numeric expressions of any number in any sequence, separated by
commas.
Examples:
if dim>x then PRINT "Opssss"
PRINT J, K-3*L
PRINT "Beginning of interpretation"
PRINT a * SIN (alpha) + b * COS (alpha)
PRINT "Parameter values: ", "a = ", a, ", b = ", b
PRINT name + STR ("%m", i) + "." + ext
commas.
Examples:
PRINT J, K-3*L
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-09 07:40 PM
2007-11-09
07:40 PM
If you want it to display on the plan you can do something like:
Keep in mind that the white text will still obscure whatever lies under it.
IF room_area > max_area THEN TEXT2 x1, y1, "Max area exceeded" ENDIFNote that the variable names (lower case) are just examples that I made up. You would need to chose whatever works for you and make sure they have the right values.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-12 04:11 PM
2007-11-12
04:11 PM
Thanks,
I'll have to also make a toggle to turn it off once I've seen the warning text.
Thanks again,
Michele
Thanks again,
Michele
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-12 08:54 PM
2007-11-12
08:54 PM
Michele wrote:What I've seen people do is create a scale-sensitive toggle in the script, use some scale that never goes to production drawings for this type of checks with script-generated information, and save that into a view. That way you don't need to mess around with object settings, and your production views and drawings are always clean and final.
