corner windows
Hello,
I searched and couldn't find an answer to this. I apologize if I didn't look hard enough.
I am trying to place a corner window in a wall. I can get it to place, but the stupid corner function keeps turning off without much logic to it. What might I be missing here?
Thanks
12 Replies 12
Erika Epstein
Is it just this file that is problematic with the corner window tool?
Are you trying to put them in a custom profile (CP) wall? If yes, instead put a empty opening in the CP wall. In the opening put a regular wall to match the opening dimensions and in this regular wall put the corner windows.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
No. Just a normal wall.
I also tried to use the method you suggested (hence the problem with the wall lengths) because the window needed to be set back and the corner window tool seems to only work if the window is flush with the wall.
Erika Epstein
Well, I'm not having a problem here doing any of what you describe. Perhaps if you post a screen shot of the problem we might see something we haven't thought of.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
