create company logo on 3d
I would like to create a custom graphics logo plus local text on a wall in a new floor entrance. I can create the graphics logo on floor plan, but unable to fit on the wall (rotate it along z axis) that the logo is supposed to hung or attache.
any help appreciated.
13 REPLIES 13
vistasp
If you're even slightly familiar with GDL, save it as an object and then use a ROT command in the 3D script.
If not, save it as an object and try using Peter's "rotator" from:
http://archicad-talk.graphisoft.com/viewtopic.php?t=24101
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Or set out in plan, convert to morph, then rotate in 3D.
vistasp
Heynock seems to be using AC 15 -- unless the sig hasn't been updated.
= v i s t a s p =
bT Square Peg
Erwin Edel
You can also use complex profile wall or beam.
Just paste your design (made with fills) and extrude the wall / beam perpindicular to the wall it needs to be mounted on.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
David Maudlin
heynock:
You can save the elements as an Object, just need to be viewing the elements from the direction you want to be the top. In the Help files (for AC15) see Virtual Building > Parametric Objects > Graphic Creation of Custom Objects > Saving 3D Models as Objects.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Oops, didn't spot that
I am using AC 15. And am still not able work it out the way I want as you told.
may be not detailed.
wish you elaborate a little further...
Here is an example of 3D Text (object made by Olivier Dentan).
Works in AC15 too.
And Here´s the object(s) in .zip file:
