Dave Brach
errors when creating 3d views
I am getting the following error message when trying to create 3d view. what to do?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
8 Replies 8
Dave Brach
this is another error message about a pen number, probably pen 0. Do I need to find the casement window and delete it?
In your stair settings (riser section) you will need to assign a building material for the risers.
This is a problem with the stair and railing library parts if you are not using a standard Graphisoft template.
All building materials, line types, pens, fills (i.e. all attributes) as set by default in the object scripts may not match those that you have in your job/template.
There are only 2 ways to fix this.
One is to edit all of the object scripts and reset all of the parameter defaults.
You will need to do this every time an new library (or update) is released.
The other is to set up a bunch of favourites with all the settings changed as you want them.
Just find the placed window object and check all the pen settings in the parameters.
If all the pens are set correctly then it could be an actual error in the object script.
DGSketcher
Legend
The riser issue is straight forward - the assigned material is missing from the library.
The pen allocation is more interesting and I noticed it in a recent object I created. Unless trapped in the GDL parameter script, it is possible to use the background pens with values 0 and -1, (window background & transparent) as a foreground fill pen which causes the error you refer to in the window. Check your pens for the window to make sure you have assigned a pen other than the background pens for any foreground fill pen.
runxel
To "trap" this you can use this code in the parameter script:
IF mypen < 1 THEN mypen = 1
PARAMETERS mypen = mypen
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Dave Brach
thanks for the responses. I guess my question is: why does archicad give me these error messages at all? I don't care about pen numbers or missing materials that don't affect my work, but my 3D views are constantly crashing and giving me these long reports that just slow me down.
I just got new message today in yet a different project .pln (attached here). Seems like this is happening more often than before and reflects a software flaw.....
Bruce
ARCHICAD gives you these error messages because that’s what they are - errors. If you want to turn these off you can do so under your work environment settings
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
This is a similar issue as the riser material.
In your stair there is an end plate used on a beam (stringer?) that has not got a valid material assigned to it.
Not so much a flaw in the software - just that you are not using the same materials in you file that the stair objects were set up for.
You can turn these error messages of in the Work Environment as mentioned, but be aware you may then miss out on more important messages.
