fill in gdl
hi all
I make gdl object from 3 slab each one has different material and fill and saved it as one gdl object when i put it again in my project it lost all material and fill how I can keep its fill and material
thank all
1 REPLY 1
Open the object's settings and go to the "Model" section.
Is the "Use objects materials" box ticked.
If not turn this on.
If it is already then you will need to delve into the mirky depths of GDL scripting.
