JGoode
for i = 1 HELP
Is there a way to use this statement but modify it to use 1 less than "num_bays"???
		for i = 1 to num_bays
			if strstr(bay_type, 'Car') then gosub "Draw Bay"
			if strstr(bay_type, 'PTW') then gosub "Draw Bay"
			if strstr(bay_type, 'Cycle') then gosub "Draw Cycle"
			add A,0, 0	! Move to next space
Thanks
ArchiCAD 27
Windows 10
5 Replies 5
Dave Seabury
FOR I = 1 TO num_bays - 1
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
JGoode
David
I tried this but no luck. I just made a num_bays_2 parameter and made it equal num_bays - 1 and it worked correctly.
ArchiCAD 27
Windows 10
Dave Seabury
J
I use this quite a bit, the only thing I can think of is
"num_bays" has to be declared before the script is
run ie it needs f to be a parameter or defined in the
master script
ds
David Maudlin
JGoode:
Another option is to start at 2:
for i = 2 to num_bays
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
JaseBee
Not sure if this is relevant to your exact problem, but there doesn't seem to be any function for switching your "bay_type" from one "i" value to the next. If they are all supposed to be the same bay type then it might be better to do your string check outside the loop so it only needs to be calculated once.
Also the strstr() function returns the integer position of the string within the string, so it might be advantageous to add ">0" to your "if strstr() then" statement, ie. "if strstr(bay_type, "Cars") > 0 then" just to avoid any funny business...
Sorry, just procrastinating my own coding issues atm.
As for the problem, I've never had any issue with the "num_bays - 1" approach, not sure what could be at issue there.
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
