graphic hotspot with 2 editable directions possible?
Mats_Knutsson
Mentor
We have a simple prism object that is editable in the Z-direction via a graphic hotspot. Is it possible to have that same hotspot also editable in the x-direction?
/Mats
MATERIAL materialAttribute_1
resol 36
unID = 1
hotspot c, -b/2, 0, unID, d, 1+128 : unID=unID+1
hotspot c, -b/2, -1, unID, d, 3+128 : unID=unID+1
hotspot c, -b/2, d, unID, d, 2 : unID=unID+1
hotspot 0, -b/2, zzyzx, unID, e, 1+128 : unID=unID+1
hotspot -1, -b/2, zzyzx, unID, e, 3+128 : unID=unID+1
hotspot e, -b/2, zzyzx, unID, e, 2 : unID=unID+1
hotspot 0, 0, zzyzx
hotspot 0, -b, zzyzx
rotx 90
cprism_{4} materialAttribute_1, materialAttribute_1, materialAttribute_1, 7,
6, B,
0, 0, 0, 15, materialAttribute_1,
A, 0, 0, 15, materialAttribute_1,
C, D, 0, 15, materialAttribute_1,
E, zzyzx, 0, 15, materialAttribute_1,
0, zzyzx, 0, 15, materialAttribute_1,
0, 0, 0, -1, materialAttribute_1
del 1
AC 25 SWE Full
Sure.
You need 2 hotspots for each point - one for the x and one for the z.
But the x hotspot need to have the z parameter in it and the z hotspot need the x.
To move the hotspot you have shown ...
hotspot 0, -b/2, d, unID, c, 1+128 : unID=unID+1
hotspot -1, -b/2, d, unID, c, 3+128 : unID=unID+1
hotspot c, -b/2, d, unID, c, 2 : unID=unID+1
6 REPLIES 6
sinceV6
Hi.
Just write the code for the other hotspot so that their positions overlap.
Best regards.
Sure.
Mats_Knutsson
Mentor
Barry wrote:
Sure.
gr8. will try when I get some time. now preparing for internal IFC-training.
AC 25 SWE Full
Mats_Knutsson
Mentor
Barry wrote:
Sure.
You're a gem Barry! I have to admit I didn't understand that you gave me the actual code... right there in front of me... Now I've got it . https://youtu.be/wMjlw6O5bfw
Thanks again.
M
AC 25 SWE Full
Mats_Knutsson wrote:
Thanks again.
M
You are welcome.
I can't say I have ever seen a dancing Archicad model before.
Mats_Knutsson
Mentor
Thanks again.
M
You are welcome.
It's a Swedish national sport... I was actually in sync but the vidcap program fps is really crap. Made me start to understand why my son is moaning about bad fps when gaming....
AC 25 SWE Full
