2016-08-09 02:21 PM
2016-08-09 02:52 PM
2016-08-09 03:00 PM
Piotr wrote:Yep, that's how I do it....crap there is no other method when there are many objects to convert. I will add some sensible names to the surfaces as well...therapy time...
Probably by exploding the original to a morph is the only option...
(do not forget to position the morph to project origin, then reset the textures...and if wiling to use in versions prior to 17 - downgrade the file with just the morphs to 16 - if the object is created from morph coming from 16 - the code can be downgraded further in AC or via xml tool)
Best Regards,
Piotr
2016-08-09 09:48 PM
2016-08-10 10:56 AM
2016-08-10 01:15 PM
Erwin wrote:Haha yes! It's a #/¤&(#/%=" studid process. I'm gonna clean up a toilet paper dispenser this afternoon. Cutting edge stuff.
Don't forget lots of coffee.![]()
2016-08-10 01:43 PM
2016-08-10 03:19 PM
Erwin wrote:Yup, All BIM. Room drawings (interior elevations) with interior and ID's.
Just out of interest, what's stopping you of dumping a 3d cube object in there with the basic dimensions and just setting up the IFC-tags to be dispenser?
Is it for 3D presentation?
2016-08-10 03:30 PM
