2017-10-27
01:49 PM
2023-05-24
01:01 PM
Rubia Torres
2017-10-27 02:17 PM
2017-10-27 02:59 PM
Erwin wrote:No, before save as an object for cabinet, i am trying to put cabinet door in plan. But can't succeed. Would you help me in creation of cabinet door? Bcoz after saving as cabinet door, i can't found the in Embedded library. That folder is showing blank.
That is not an error message, just an information prompt telling you the object was saved in embedded library.
These are custom panels you can use for some of the kitchen library parts. You will have to choose custom panel and you should see a list of the ones you've saved to embedded library there.
If you've modelled the entire kitchen part as object, you should just save it as an object, not a kitchen cabinet door.
2017-10-27 03:08 PM
2020-06-09 12:20 PM
2020-06-10 03:08 AM
Roopa wrote:
created object using morph and object which is downloaded from archibase
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2020-06-10 09:12 AM
2020-06-12 01:53 PM
2020-06-15 03:03 AM
Roopa wrote:
The object which I saved as object(.gsm) file, it is opening in one file, but when I try to open that in other main file where I want this object, It;s not coming, it's showing as invalid 3D symbol, open the library part for editing and check its 3D script for errors.
Why it is showing this??
2020-06-15 07:19 AM
