2018-05-15 01:25 PM
2018-05-15 04:27 PM
2018-05-16 07:58 AM
Dave wrote:Which library is this in? I cannot find it in the AC21 AUS default library.
the scripting (master script) of the DET_Stud object in the standard library.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2018-05-16 08:45 AM
n=SPLIT(optx, "%nx%n", width, string, height) A = width/1000 B = height/1000 PARAMETERS A = A PARAMETERS B = BIt is best to set the value of your parameter as well as set the actual parameter.
2018-05-16 08:52 AM
Luiscardoso wrote:It depends on what you are changing as it can affect already placed objects if you change the way the existing scripts work.
I plan on using this object in different projects (saving it in a container file) and keep adding versions with (with on off buttons or values) of it as time go on (updating the container file every time) . Do you see any problem with this method? will my previous placed objects be fine or will they change?
2018-05-16 08:53 AM
2018-05-17 09:52 AM
