project2 & cut fills
Hey all,
I've just started down the path of scripting my own objects, and I'm simply searching for a way to make the regular plan 2D view of the object look as it does in the Section or 3D Doc/Plan view.
I've attached an example file of what I'm trying so far. The upper block would ideally be filled with a user selected cut fill and the lower block would just be outlined.
(Basically the way I would want every object to be displayed by default, cut at the level of the floor plan view)
Thanks!
I can't seem to attach .gsm .....so here is the code:
2D-----------------------------------------------
SECT_ATTRS fill2, pen1,
pen2, pen2
PROJECT2{3} 2,270,2+16+4092,15
3D-----------------------------------------------
IF GLOB_CONTEXT =2 THEN
ADDz 1.5
CUTPLANE
DEL 1
ENDIF
MATERIAL mmat
BLOCK 1,1,1
ADD 1,1,1
BLOCK 1,1,1
DEL 1
IF GLOB_CONTEXT=2 THEN CUTEND
END
8 REPLIES 8
I think you will have to use the extended version of this command:
PROJECT2{3} projection_code, angle, method, parts [, backgroundColor,
fillOrigoX, fillOrigoY, filldirection][[,]
PARAMETERS name1=value1, ..., namen=valuen]
So to achieve this particular result you need to provide not only the first 4 parameters, but at least the next 4 parameters as well. Those define the cut fill's background color and the origin and direction of its pattern.
These parantheses - [] - mean that those parameters included within them are optional parameters.
For example, this code:
PROJECT2{3} 2,270,2+16+4092,15, 19, 0, 0, 0
I suppose would set the background fill color to Pen 19 (usually white), the Fill's origin will be at 0, 0 in the X-Y plane of the Object, and its direction will be the direction of the X axis.
I did not try it, but let's hope that is what those values mean. The GDL Manual is not too verbose on these parameters and there is no example for their use either.
Thanks Las, but adding those parameters did not seem to change anything.
Does the SECT_ATTRS definition apply to shapes cut with the CUTPLANE?
After a bit more digging I found this:
http://www.masterscript.nl/3d-objects/38-object-slicer.html
(which seems like what I am trying to do)
and this discussion:
http://archicad-talk.graphisoft.com/viewtopic.php?t=25373&sid=e85f9fa3bf041751b42b4403e909a7de
Am I missing something obvious - doesn't everybody want their objects to simply be cut with the floor plan?
(and not waste time writing a duplicate script in 2D that has to be updated with any changes to the 3D shape)
David Maudlin
It just depends on the object and the desired plan view, the vast majority of objects I have created do not have a cut plane, mostly a simplified top down view.
Except for very complicated shapes where an accurate top down view is needed, a 2D Script is better: it runs faster without the overhead of creating a 3D view for each object's representation in plan view. A lot of objects using Project2 will take unnecessary resources for plan generation. Some of the code used for the 3D object can be reused for the 2D Script, with a change in command and editing some of the variables.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Pertti Paasky
"SECT_ATTRS fill2, pen1....", should be in 3d script, not in 2d.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Ok, that makes sense. After playing around a bit more it seems that objects cut with a CUTPLANE do not count at cut polygons in PROJECT2{3}....?????
Changing the 4th parameter between 3,12 and 15 shows that the shapes are not recognised as being cut.
----------------2D----------------------
PROJECT2{3} 2,270,2+16+4096,15,19,0,0,0
----------------3D----------------------
ADDz 1.5
CUTPLANE
DEL 1
SECT_FILL fill2, pen1, pen2, pen2
MATERIAL mmat
BLOCK 1,1,1
ADD 1,1,1
BLOCK 1,1,1
DEL 1
CUTEND
END
Pertti Paasky
Here's an example. It takes it's time to go through it.
I try to attach "FloorPlanCutPlane.gsm" but no success...somebody help?
OK, Thank You, Lazlo!
Create a ZIP file out of it, you will be able to upload that.
Thanks Pertti, that was a really helpful script - it seems to do everything.
For the moment I will stick to something a bit simpler, the key information was that it appears that CUTPLANE{2} has to be used to generate cut polygons - I had no idea.
As soon as I switched CUTPLANE for CUTPLANE{2} 0,0 it all looked good.
