‎2008-03-14
08:18 AM
‎2023-05-24
12:43 PM
Rubia Torres
‎2008-03-14 10:00 AM
‎2008-03-14 10:47 AM
‎2008-03-15 01:26 AM
Vic wrote:Vic, the scripting today is extremely complex compared to earlier versions.
/...I need the red lines removed from the 2D symbol.
This way it is clear the window is sliding. With the extra lines it's hard to tell from a regular window.
I dont know why this option was removed after ArchiCAD 8.
‎2008-03-15 02:11 AM
‎2008-03-15 03:07 AM
Peter wrote:Good advice, Peter.
So is mine, well extremely edited 6.5 parts. The 6.5 library is still
available and it makes much less use of macros than later versions
so it is much easier to isolate the macros needed. Vic might consider
the 6.5 version of this part ( if it existed) to use in AC 11.
Peter Devlin
‎2008-03-15 04:32 AM
‎2008-03-15 05:01 AM
Peter wrote:Agreed, and well put.
Since Graphisoft has gone to a twelve month
cycle, users do not have the time required to
discover problems and issues with the program
and it certainly does not give the programmers at GS time
to fix the problems before they are forced on to a new
version./....
‎2008-03-15 04:42 PM
Rod wrote:I tried that and it gives me "Incompatible types in expression" errors when I try to use it,
Copy and rename the window from 8 that works the way you want,
then load that into your project library.
Just beware that it too, may call macros, which will need to be loaded in your working library.
Copy those to a folder, named Macros XX. This may throw up messages of duplicate parts,
but you will have your window as you wish.
‎2008-03-16 01:48 AM
Vic wrote:Vic, attached find zipped window with macros saved from V 8.1.
Both of you said you use old library parts in your ArchiCAD 11 library - that makes me hopeful you could help me
use the old window in version 11.
Could you guide me through the process somehow?
