Read articles about Archicad and BIMcloud libraries, their management and migration, objects and other library parts, etc.
Articles
Converting IFC files into GDL Objects
Using IFC content can be a great tool in building up a custom library. Follow the steps below to convert IFC content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the IFC file to import, check the box next to Launch a new i...
wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-1.32.24-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-1.33.07-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-1.35.01-PM-1.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-1.35.21-PM.png
Converting 3D DXF/DWG Files into GDL Objects
Using 3D DXF/DWG content can be a great tool in building up a custom library. Follow the steps below to convert 3D DXF/DWG content into GDL objects. 1. Go to File > Libraries and Objects > Import Blocks from DXF/DWG. 2. Select the DWG file to import ...
wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.20.41-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.21.43-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.30.35-AM.png
Converting SketchUp files into GDL Objects
Using SketchUp content can be a great tool in building up a custom library. Follow the steps below to convert SketchUp content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the SketchUp file to import, check the box next to...
wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-2.51.12-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-3.03.16-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-3.03.41-PM-1.png
Converting STL files into GDL Objects
Using STL (StereoLithography File) content can be a great tool in building up a custom library. Follow the steps below to convert STL content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the STL file to import, check the b...
wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-1.42.25-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-1.17.42-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-1.50.15-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-10-at-1.53.15-PM.png
GDL Object Downloads for ARCHICAD
Objects on BIMcomponents.com ARCHICAD’s modeling capabilities, connected with the cloud-based BIM Component database allows you to create, search, upload, and download custom BIM components of your choice. The fully-integrated web portal makes sharin...
wp-content_uploads_archicadwiki_linkcollection-gdlobjectdownloads--bim_components.jpg
