2012-02-20
05:03 AM
2023-05-24
12:36 PM
Rubia Torres
2012-02-20 03:18 PM
2012-02-21 12:28 AM
2012-02-21 01:12 AM
leporello wrote:Check out Cadimage Doors and Windows, I haven't used standard Archicad doors or windows for years. Alternatively you might be able to get hold of the Modular Joinery Object mentioned in this thread.
In the Thinking Out Loud department, there are so many windows and doors now, that it seems a simpler approach might be possible - a single uber-opening that can do anything and includes some presets to get a new user started.
2012-02-21 02:35 AM
s2art wrote:Coincidentally, I just gave the trial version of Cadimage Doors/Windows a whirl to see if it got me past some glitches in the AC lib. Alas, it had its own limitations vis a vis the US library - most notably not having the ability to use different sized trim pieces for verticals vs horizontals, and not having different wall insertion modes (called 'wall closure' in our UI), with the ability to automatically cut back skins for insertion of exterior trim. I continue to find Doors/Windows consume an inordinate amount of time due to fighting with bugs and limitations.
2012-02-21 02:18 PM
leporello wrote:Unfortunately, I don't think there is such a document. This Basic Library Doc is the closest there is.
What I was looking for was less a gdl technician's manual than a detailed user's manual, making it easier to select from within the bewildering variety of separate window objects by explaining their differences, as well as moving smoothly through the bewildering array of toggles and tweaks within each window. Same for doors.
2012-02-21 03:41 PM
