‎2008-12-14
08:07 PM
‎2023-05-25
06:11 PM
Rubia Torres
‎2008-12-15 05:47 PM
‎2008-12-15 05:56 PM
laszlonagy wrote:
When you are doing the tutorial, are you only watching the movie or are you also reading the PDF?
Because the PDF has a lot of info about the things you are doing. Many times based on what you read in the PDF you can search the Help file and it can give you a lot of info.
‎2008-12-15 06:07 PM
NStocks wrote:No, the zone tool is used to mark a volume inside a building. Its simplest use can be to just display something simple like its room name, area or volume on the plan in a zone stamp, or you can use it to do more complex things like schedules by listing all the objects that may fall in it, like doors or furniture etc.
I am watching the tutorial again, so that I get more experience with it all. The ' zone ' tool, is this just like a outline as to where other elements will be places, and built up on, For instance, when they place a grid across the whole zone, as soon as another element is selected i.e. column, it will place a column at the intersection of the zone and grid ?
‎2008-12-15 06:14 PM
Peter wrote:NStocks wrote:No, the zone tool is used to mark a volume inside a building. Its simplest use can be to just display something simple like its room name, area or volume on the plan in a zone stamp, or you can use it to do more complex things like schedules by listing all the objects that may fall in it, like doors or furniture etc.
I wouldn't worry too much about it to start with, just be aware of its capabilities. Get the basics done first.
And seriously, try to find someone to show you the basics in person. You will learn more in 10 minutes than you can by yourself in many hours!
‎2008-12-15 06:57 PM
NStocks wrote:Some people are just selfish, aren't they!
...plus he has just had his 2nd baby... so I don't think he will want to spent time with me.
‎2008-12-15 07:08 PM
‎2008-12-15 07:10 PM
‎2008-12-16 03:13 AM
‎2008-12-16 03:15 PM
‎2008-12-16 03:21 PM
