2008-12-14
		08:07 PM
		2023-05-25
		06:11 PM
			Rubia Torres
2008-12-16 04:11 PM
2008-12-16 04:36 PM
2008-12-16 04:57 PM
 2008-12-16 05:08 PM
NStocks wrote:I'm not entirely sure what you mean. Was there meant to be something attached to your previous post? Use the browse button under the message composing box to attach an image; a picture is worth a thousand words!
Ok this is one of the problems I'm having with the stories. I have use the setting within so that the height to the next is 0, so in reality there shouldn't be a gap ( right ? )
2008-12-16 05:21 PM
Dwight wrote:Yeah there was suppose to be something attached but that doesn't matter now.
A two storey building can be managed with layer visibility and not necessarily by creating separate storeys. You make layer sets to study different building aspects.
One of the advantages of separate storeys in a project is to force elements to relate directly to a storey level.....
Experiment with both ways and see what works for you. Most challenging in a situation like this is with what we call a "Split-level" dwelling.
Another factor is the floor plan cutting plane issue - where, in each storey, the slice is taken.....
2008-12-16 06:41 PM
2008-12-16 07:04 PM
2008-12-16 07:07 PM
2008-12-16 07:12 PM
2008-12-16 07:22 PM
 Thank you, it works ! One more question what does elevation mean on story settings ?, and if I am copying and pasting the ground floor to the second floor, would/should the slab be the same thickness in reality ?
