2008-12-14
08:07 PM
- last edited on
2023-05-25
06:11 PM
by
Rubia Torres
2008-12-16 07:24 PM
NStocks wrote:What exactly do you mean by this?
I can't get crop to work in preview ( Mac )
2008-12-16 07:25 PM
2008-12-16 07:53 PM
NStocks wrote:It looks like you haven't drawn the walls high enough on the ground floor. They should probably be the same as the storey height.
Ok, this is what I got :
..what does elevation mean on story settings?..It's just a running total measuring from ground 0.000m level. You can enter the heights in there if you like. If you change one the other heights will update also.
and if I am copying and pasting the ground floor to the second floor, would/should the slab be the same thickness in reality ?Sometimes, but not normally. It depends entirely on how the floors are constructed. In the UK the typical domestic ground floor buildup is 150 hardcore, 150 conc slab, dpm, 50-75 insulation, 75 screed, then the floor finish.
2008-12-16 08:12 PM
2008-12-16 08:33 PM
2008-12-16 09:03 PM
2008-12-16 09:25 PM
NStocks wrote:No, you wont see the section in 3d. The section will open up in its own window. (See Part 5, paragraph 4. above)
I'm having a problem with the section tool. I have configured the settings but when I draw a line and press the mouse when the eye appears, the section line is placed, although I can't see the section in 3d mode. Should i be using a different mode for viewing sections ?
2008-12-17 02:20 AM
And sorry about the image, I can't get crop to work in preview ( Mac )
2008-12-17 02:23 AM
Peter wrote:NStocks wrote:No, you wont see the section in 3d. The section will open up in its own window. (See Part 5, paragraph 4. above)
It is purely a 2 dimensional view of the model.
2008-12-19 05:17 PM
Peter wrote:Just to spice this up: you CAN see the section in 3D, using Special menu, but it is still lost in the distance before you ... first do the "usual" sections.NStocks wrote:No, you wont see the section in 3d. The section will open up in its own window. (See Part 5, paragraph 4. above)
