2019-10-04
01:35 AM
2025-10-25
06:04 PM
2019-10-04 02:34 AM
2021-11-16 06:26 PM
So this essentially means that Archicad can only render a pixel as either 100% opaque or 100% transparent, is that correct? The suggested work-around seems like a non-starter as it is labor intensive and will not produce very good results.
Does this limitation still persist in version 25?
2022-11-17 01:26 AM
Hello ! You can do it by creating a new worksheets in the right column and drag-and-drop your png image, next you go back to your main document and use the worksheet as a trace (in trace and comparison options), you slide down the opacity en you're good ! Enjoy
Bonus : https://architectsworkshop.in/webtools/highres/
A link for downloading fastly the best aerial images you can have for free (google satellite) ^^
2022-11-17 03:10 AM
Hi Alskaro. Your suggestion works for creating transparency in your working view, but I don't believe it can be printed. Is that correct?
2022-11-17 11:16 AM
Hello! I don’t know how to do it if it’s possible, some people says it is something to do with the views but I don’t know how because other peoples says trace can’t we printed in lower opacity because the pdf can’t handle it… I neither know how to print construct grid, maybe something missing in Archicad too ..
2024-08-15 03:55 PM
Graphisoft - will you please chip in here. I know this can be done. Can you provide a tutorial or a link to one?
2025-10-25 12:07 AM
You just need to put a white fill with gradation like 50% between for your pixeld drawing and your vector drawing on the layout. Pixeld drawig is to arrange to the back and the vector drawing to the front with transparancy settings. For the real magic it just still need some little bit of fine tuning in your view settings and in my opninion is this the fastest work around.
