2014-03-19
11:24 PM
2023-05-26
02:21 PM
Rubia Torres
2014-03-20 01:04 AM
2014-03-20 02:09 AM
2014-03-20 02:37 AM
Show Editing Plane During Editing Operations Only
If the Editing Plane Display toggle is on (View > Editing Plane Display) – and it is on by default – you can still limit its appearance using this checkbox, at Options > Work Environment > On-Screen Options.
If you check this box, the Editing Plane will appear only during the time you are actively editing in the 3D window (provided that the “Editing Plane Display” toggle is turned on.) When you are done with the operation, the Editing Plane disappears.
another Moderator
2014-03-20 02:51 AM
