3D Projection Settings
Dave Jochum
This occurs many times a day--I'll be working in plan with a tight zoom, I'll click on a 3d view in the navigator, then decide I want to view from an angle I haven't set up yet. So I'll go to Image/3D Projection Settings... to position the view, and since the plan was left in a zoomed in state I can't do the positioning without going back to the plan and zooming out first. There should be a way to zoom out in the 3D Projection Settings plan window. Is there and I'm just missing it?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
6 REPLIES 6
I'm sure it happens to everyone. As far as I know, you're not missing anything.
If the camera target is within what you see on the 3D projection settings window, what I do is just drag the vector (changing the view point) and play with the Distance option.
Luc
Djordje
Ace
You are missing it. You can zoom Navigator Preview! And not only that - you can view from the side, with stories shown.
If you want the camera in the 3D settings zoomed window:
Shift click places the camera
CTRL click places the target
ALT click places the viewing direction vector
Now, I wish the three above worked in Navigator preview! Time to visit the Wishlist forum
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dave Jochum
Yes, but that doesn't help in the situation I described. When you have the 3D Projection Settings window open you cannot access the Navigator Preview window.
I use these, however, if you aren't zoomed out far enough to show the points where you want the camera or target, they are useless.
Dave Jochum
Djordje
Ace
Ooops ... you are right!
However, since the 3D is so much faster, i rarely have the need to go to the 3D settings. Maybe that is why I read your message wrongly?
The wish to zoom the 3D settings window is a long standing one, BTW ...
Djordje
HP Omen
Dave Jochum
Djordje wrote:
...since the 3D is so much faster, i rarely have the need to go to the 3D settings.
You're refering to Open GL navigation in the 3D window? I'm glad to hear you say that, because it is way too slow on my machine due to my museum piece graphics card. I'll be getting a "real" card as soon as they're in stock. It's such a treat to work in SketchUp--even on my machine I can rotate around a model as quickly as I can move the trackball.
Dave Jochum
Djordje
Ace
Yep; I am walking through a big model with full interior without a glitch. Good graphics are NEEDED!
Djordje
HP Omen
