3d elevation change story of elements
Hello to everyone. When i elevate in 3d window walls, slabs etc they change story even if the elevation is about 20cm.
Is there any way to prevent this??? to keep their story while elevating??
I use plan view with symbolic cut or outline for home story only..
thanks in advance
AC12, Dell StudioXPs
3 Replies 3
sorry ac13
You may have 'Set Home Storey by Elevation' ticked in the Elevate dialog box.
Also check your Storey settings. You may have one storey set too low perhaps. A nice visual way to do this is to just have a look on one of the sections through the building with the story levels turned on. It will be obvious if anything is incorrect.
Hope that helps.
I used elevate command (ctrl+9) (unchecked the box set home story by elevation) instead of elevate button in the floating toolbar and worked perfectly.
thank you very very much.
