norabela
3d vectorial hatching menu missing! can not display
In Archicad 20 I can not tick the "3d vectorial hatching" menu point in the "selected section setting menu", because it's completely missing.
Has it been moved, or it's an installation problem, how do we recover it? The whole office has the same problem.
3 Replies 3
Eduardo Rolon
If "Nothing" is selected in the "Fill Uncut Surface with" setting then the Vectorial Hatching is hidden.
If this is not a BUG then it should be.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
norabela
Thanks, that worked! I didn't know you have to set it to that.
Eduardo Rolon
I think it is a Bug. It should not do that.
AC29 US/INT -> AC08
