SimSmi1
4 way wall intersection
Hi all, I am having trouble getting a staggered intersection between 4 walls to work cleanly. My current result is:
 Reference lines are as follows:
In Revit I would have just hidden the rogue line but if I can't get this to work then I guess the only option is a 2D patch fill (which i's rather avoid if I can). Any help would be most appreciated, Thanks
6 Replies 6
Lpalma
You could solve that intersection with a piece of wall the full width of the intersection.
I hope this helps.
Lpalma
Putting the reference lines on the "outside" of the intersection often works in such situations.
Hope that helps,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Or you can mirror the reference line for this wall.
*And then stretch it to the nearest edge.
Screenshot 2026-05-14 212646.pngScreenshot 2026-05-14 212659.pngScreenshot 2026-05-14 212704.png
AC 29 INT 4006/WIN 11
Another method is to model the central Wall geometry using the "Polygonal" Geometry Method and let all the other Walls join that geometry.
(This works only for non-composite walls.)
Eduardo Rolon
Or you can use a column for the classic workaround from 2010.
https://onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
SimSmi1
Amazing, thanks everyone!
