2005-07-30
06:53 PM
2023-05-24
12:23 PM
Rubia Torres
2005-07-31 01:08 PM
gpowless wrote:My Tipp is: do that all with "Solid Element Operations...", using substruction tools.
My method involves making the entire terrain, first. Then I layout the lines where I want my walkway or driveway paving, and cut out a 1' band around the perimeter of the driveway...
Gregg
2005-07-31 06:13 PM
2005-08-04 05:53 AM
2005-08-05 03:05 AM
gpowless wrote:Sorry to be a bit thick.
I just cut a band on either side of it to separate the mesh in much the same way that a cookie cutter separates dough. Then after I have made adjustments, I use offset to slide the edges over until they touch.
For accuracy I often draw a series of lines and then cut out about a 1 fot section along the line.
2005-08-05 03:07 PM
2005-08-07 11:02 PM
2005-08-08 07:31 AM
Walter wrote:You could have a second mesh which is intact. It could be lowered to give the kerb setdowns
A great idea but how do you cut a mesh to the shape of a driveway but still keep the "driveway" section of the mesh?
2005-08-08 02:56 PM
You could have a second mesh which is intact. It could be lowered to give the kerb setdownsI had no patience for the double line cookie cutter so "excavated" the mesh in the shape of the drive as gpowless suggests with the "-" pet tool after copying the mesh, lowering the copy & changing it's material.
