AC 12: Explore Model very clunky...
I frequently use the "Explore Model" option to fly around the building and see if everything is working smoothly. Since upgrading to 12, whenever I use the Explore Model, it does nothing the first time. I select the "little man" icon, and usually I can navigate right away. Now, it temporarily freezes the screen. I have to push escape and do it again, sometimes 3 times before I can actually explore.
Is this a bug that needs to be fixed or is there a way around this?
Anyone else have this happen??
25 REPLIES 25
kevin b
Works fine for me.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
It has been working better as I go along, but still jams up occasionally.
Are you sure you are using OpenGL?
I just tried it and had no problems at all. Much faster than 11.
I am using Open GL. It's strange because I opened a different project and it's working fine, but then some other models sometimes freeze up. I have a brand spanking new computer so I know that is not the issue.
I agree when it is working it is much faster than 11.
Maybe my squirrel bodyguard should slap it around
Gerald Hoffman
Let me know if you need some help.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
I almost wet myself laughing... what are the chances of two super ArchiCAD squirrels on the same post?
