AC 12: Explore Model very clunky...
I frequently use the "Explore Model" option to fly around the building and see if everything is working smoothly. Since upgrading to 12, whenever I use the Explore Model, it does nothing the first time. I select the "little man" icon, and usually I can navigate right away. Now, it temporarily freezes the screen. I have to push escape and do it again, sometimes 3 times before I can actually explore.
Is this a bug that needs to be fixed or is there a way around this?
Anyone else have this happen??
25 REPLIES 25
kevin b
Works fine for me.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
It has been working better as I go along, but still jams up occasionally.
Are you sure you are using OpenGL?
I just tried it and had no problems at all. Much faster than 11.
I am using Open GL. It's strange because I opened a different project and it's working fine, but then some other models sometimes freeze up. I have a brand spanking new computer so I know that is not the issue.
I agree when it is working it is much faster than 11.
Maybe my squirrel bodyguard should slap it around
Let me know if you need some help.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
I almost wet myself laughing... what are the chances of two super ArchiCAD squirrels on the same post?
