AC10 3D window shortcut non-standard ?
Eduardo Rolon
I just started to play around with 10 and found that the mouse button shortcuts for Orbit and Pan are inverted. Usually for Orbit you press the mouse wheel and for pan you add Shift, since usually you want to do Orbit more than Pan on the 3D view. Imagine the confusion from switching from working in SketchUp to AC.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
10 REPLIES 10
Djordje
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
