2006-06-08
11:58 PM
2023-05-23
05:15 PM
Rubia Torres
2006-06-24 08:30 PM
Djordje wrote:This seem like a bug to me. Sometimes you can get the pet palette and sometimes it changes the selection. I have a sneaky unconfirmed suspicion that it relates to being selected with the magnet. The 3D window has some strange bugs related selection with the magnet tool.TomWaltz wrote:This is probably it; the described happens if you are in the Arrow tool.
It also helps to have "Slab" as the active tool, not just a slab selected.
2006-06-25 05:40 AM
Mike wrote:Not really.Djordje wrote:This seem like a bug to me. Sometimes you can get the pet palette and sometimes it changes the selection. I have a sneaky unconfirmed suspicion that it relates to being selected with the magnet. The 3D window has some strange bugs related selection with the magnet tool.TomWaltz wrote:This is probably it; the described happens if you are in the Arrow tool.
2006-06-26 06:47 AM
Djordje wrote:The fact that the results are variable indicates a bug. If it works sometimes but not other this is not consistent. Most editing can be done in the arrow tool (or any other tool that you happen to be in) and this increased functionality was given to us several versions back and it should not act in this manner. There is always a way to do something, but ideally the task can be done in a number of different methods and the same result achieved. Select a slab via a node in the arrow tool and click on the edge of the slab (mercedes) and tell me why it brings up the pet palette when at other times it selects a wall at the same location.
Not really.
It depends on the active tool - make it a habit to Select and activate tool, and many problems will go away.
2006-06-26 03:11 PM
2006-06-26 03:44 PM
2006-06-27 06:18 AM
2006-06-27 06:38 AM
2006-06-27 06:43 AM
2006-06-27 11:19 AM
Pete wrote:
How did I miss this thread? This behavior is what I was referring to in the other thread. Trying hard enough... tap, tap, tapping the Tab key... I can get the work done, but frustratingly slow! I'm afraid the pattern is that there is no pattern.
Similarly, I cannot seem to select a roof and then edit the pivot line. I'll start a new thread on that (after checking for an existing one).
2006-06-27 04:08 PM
