Eduardo Rolon
AC11 Detail Break Line
Has the Break Line for details been removed in the upgrade? If not where is it?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
24 Replies 24
TomWaltz
I'm kind of confused here... what break line? I don't see a break line anywhere even involved in the detail.
Tom Waltz
Eduardo Rolon
From AC10, it should have said "break point" instead of line
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
And for something completely different. The Arrow Marker can only be used for indicating upward and from the right. Downwards and to the left is different.
am I being difficult?
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
pointing down and to the left
AC29 US/INT -> AC08
another Moderator
Just a note that this issue appears to be fixed now...
Richard
AC26 (since AC6.0), Win10
Eduardo Rolon
Which one works?
tried every variation of AC11 marker and can't seem to find it.
AC29 US/INT -> AC08
another Moderator
This was "Detail Indicator_NCS", rectangle construction method . Make sure you have the latest library version.
Richard
Eduardo Rolon
I have the latest library. Within it I have the option for Detail Indicator_2NCS.
AC10's Markers are working fine with the new update. What has me a little down is that AC11 do not seem to work and that is the upgrade.
AC29 US/INT -> AC08
another Moderator
Eduardo,
Your screenshot shows Detail Indicator 2. This one didn't work so well. If you don't have the Detail Indicator without the "2", I can probably send it to you.
Richard
Eduardo Rolon
Check your PM.
AC29 US/INT -> AC08
another Moderator
