AC17 interior elevations
I have place an interior elevation (for an entire room) and when I try to drag one of the points of view from the initial location, the view moves to be that of another. I can drag all the other views and they also change to be another view. If I continue the pattern I eventually end up with all 4 elevations. Why is this happening?
1 REPLY 1
vfrontiers
I was told it's a bug and they're working to resolve it by next HotFix.
They also mentioned that if you place as a POLYGON (instead of a square), it will not happen... Haven't tried it yet...
I've been dragging all four till they STICK in place...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
