AC21 Composite Wall wrapped end
I am not sure if I am missing a beat here, but I seem to be having an issue wrapping the end of a composite cavity wall. The behavior works well with the return end option, but not the wrapped option. All I am trying to do is wrap the brick and plaster skin together.
Thanks
insideru
Is this what you are looking for?
ARCHICAD 28 INT
macOS Sequoia
insideru
ARCHICAD 28 INT
macOS Sequoia
Aah thanks, you are a star, that worked.
